It is currently Fri Oct 04, 2024 1:13 am
Post new topic Reply to topic  [ 11 posts ]
Would you live in a tree?
Yes 67%  67%  [ 2 ]
Perhaps, I'd have to think about it 33%  33%  [ 1 ]
No Way! 0%  0%  [ 0 ]
Total votes : 3
 Post subject: Tree Housing
PostPosted: Tue Oct 21, 2008 11:47 am
How about living in Trees. And not just in the branches, in the actual tree itself?
The Giant Sequoia can grow to massive diameters, with some measuring 20-30 metres (although I think it may be more like 20-30 feet. Butr still, that is a lot of room). Now, assuming we are skilled enough (and I believe it has been done before, so we are) it should be possible to dig houses inside the tree. There should be plenty of room, even if we can only use half. Have a spiral staricase up the hardwood core, and then dig upwards. A mansion could be constructed out of one of these trees. For those concerned about their 'Carbon Footprint' this could be the perfect house. Throw in the extra amount available on the branches, and your set!
(I have found no prior art on this oln the first google hit page for 'Living inside a tree'.)
Assuming their growth can be accelerated using Genetic Engineering and other, more 'natural' means (increased sunlight using mirrors, increased CO2, increased water) then we could soon all be living in trees.
(This ties in with my Imagine thread)
 Post subject:
PostPosted: Tue Oct 21, 2008 5:40 pm
Grand Master Venerable Dragon
Another tree to check out is the Baobab Tree from Africa. But it does take a lot more than just quick growing a tree to work out like that. The wood of a quick grown tree is "softer" than one that takes its time to grow. And may make the trunk unable to support itself. And most trees (at least with the Baobab) naturally create the hollow, and are seldom worked by hand. But that is an idea.
The victories from those skilled in warfare are not considered of great wisdom or courage, because their victories have no miscalculations
- SUN-TZU
 Post subject:
PostPosted: Tue Oct 28, 2008 3:18 pm
The Endless Prophet
I have a whole worldbase that uses a tree for the main setting. The 'plane' (if I may), is an (effectively) endless flat landscape covered in trees of varying sizes. The largest of these are truly massive organisms that have grown such that their interiors (once hollowed) and any constructions around teh outside can house populations in the low billions.
"Thunder is good, thunder is impressive, but it's lightning that does the work." ~Samuel Clemens
Mah Griffon is © Todd Lockwood.
 Post subject:
PostPosted: Wed Oct 29, 2008 2:02 pm
Wandering Dragon
It would be a sound idea and I believ many people would try it. Have they actually put this idea into practice yet, to see if it would work?
 Post subject:
PostPosted: Wed Oct 29, 2008 6:32 pm
Partly. There's a house somewhere that is constructed from a Baobab tree, and a pub as well.
 Post subject:
PostPosted: Mon Nov 03, 2008 6:19 am
Godsin Queen
the prob is if you couldn't just farm a tree like that you'd be stuck living where ever you planted the tree, that would defently complicate things for the guy growing all these trees. He couldn't just plant a whole bunch of trees in a row then harvest the wood. They would have to select places for each and every tree intended to be used for a house. depending on how far away they made each house from the other could you imagen the work it would take to mass produce these houses?
~Once I knew who I was, until I met someone who knew me even better.~
Imagehttp://dragcave.net/incubators/incubator_Mirravin.png
 Post subject:
PostPosted: Mon Nov 03, 2008 9:16 am
Yes, I can. It would take almost as much work as building a house.
And with a stone house you're still stuck where you built it.
 Post subject:
PostPosted: Mon Nov 03, 2008 4:03 pm
Ah, lad. But stone you can trust. That tree will one day die and rot away. But a solid stone house will stand almost forever. [/dwarf mode]
But really check out these two places. Cliff side cities.
http://www.roadsideamerica.com/story/10362
http://archive.cyark.org/mesa-verde-gallery-photograph
- SUN-TZU
 Post subject:
PostPosted: Tue Nov 04, 2008 6:24 am
But stone is dead. A tree you can feel its pulse. But stone is cold and dead.
I know about those cliffside cities. I also have ideas for living inside the stone...
 Post subject:
PostPosted: Wed Nov 05, 2008 12:42 am
Godsin Queen
I find stone rather cool and relaxing, now if I lived in a living tree I'd proubly have nightmares about it growing vines and strangleing me or it eating me or something. The thought of living in a living thing is rathrew creepy to me.
 Post subject:
PostPosted: Wed Nov 05, 2008 3:03 pm
Matrix Operator
I don't know, I kind of like the idea.
The devil doesn't come dressed in a red cape and pointy horns. He comes as everything you've ever wished for.
-Tucker Max
Users browsing this forum: No registered users and 1 guest
You cannot reply to topics in this forum
