It is currently Mon May 20, 2024 11:08 am
 Post subject: The board has been updated to v3.0.6
PostPosted: Thu Nov 19, 2009 11:12 am
This update fixes numerous bugs, introduces some major features, as well as improves stability and performance.
* Show error in the ACP when template folder is not readable.
* Correctly apply the can change vote permission again. Regression introduced in r9470.
* Remove data from friend/foe table when deleting user.
* [Fix] dynamic config update routine error if firebird is used
* [Fix] saving custom profile fields in ACP if Oracle is used.
* Make view_log() more resilient to corrupt serialized data.
* [Fix] Oracle database backup and restore.
* Update attachments table when deleting user and retaining his posts.
* Correctly detect files in subfolders when viewing cached template files.
* Do not throw an error when PDO is a shared module and not loaded preventing SQLite from being loaded.
* [Fix] censoring of unicode words.
* Do not remove recipients when loading private message draft.
* [Fix] database updater and db tools to support multiple column changes/additions/removals with SQLite.
* Posting smilies in view more smilies screen now works again in IE.
* Add ability to prune users who never logged in.
* Fail gracefully if store folder is not writable during update.
* [Fix] error with disapproval of topics having several queued posts only.
* Preserve newlines in template files.
* Be less strict with FTP daemons when getting directory filelists.
* [Fix] set_custom_template for database-stored styles.
* Do not send private message back to sender if sender is in the same group the private message was sent to.
* Min/max characters per posts no longer affects poll options.
* Do not try to create thumbnails for images we cannot open properly.
* Apply locale-independent basename() to attachment filenames. New function added: utf8_basename(). (Patch by ocean=Yohsuke)
* Adjust build_url() to not prepend $phpbb_root_path if path returned from redirect() is an URL. This fixes redirect issues with some installations and bridges.
* [Fix] general error in registration, caused by an undefined $config variable in validate_referer().
* Correctly extract column default value when exporting PostgreSQL tables.
* Allow updater to work correctly with PHP filename extensions other than ".php".
* Update search index if only post subject changed.
* Prevent style switcher from blocking the tab key.
* [Fix] email problems on servers with PHP installations not accepting RFC-compliant subject string passed to the mail()-function.
* Only embed cron.php if there is no cron lock present to reduce overhead.
* Send activation email when activating user from user settings.
* Correctly display underlined links placed in last line in viewtopic.
* Only check whether forum image exists if forum image is specified.
* Fixed database updater for changes to columns having default value in MSSQL (adding/dropping constraints).
Users browsing this forum: No registered users and 6 guests
