It is currently Wed May 29, 2024 7:15 pm
 Post subject: The board has been updated to v3.0.7
PostPosted: Tue Mar 02, 2010 11:43 am
This update is a maintenance release fixing a number of a bugs as well as improving on usability and performance.
* Warn users about potentially dangerous BBcodes.
* Forum feed no longer includes posts of subforums.
* Speed up topic move operation by adding an index for topic_id on the topics track table. (Bug #56545)
* Move redirect into a hidden field to avoid issues with mod_security. (Bug #54145)
* Log user activations through inactive users ACP. (Bug #30145)
* Alter ACP user quick tools interface to reduce confusion with the delete operation.
* Show a proper preview for the Q&A CAPTCHA. (Bug #56365)
* Send time of last item instead of current time in ATOM Feeds. (Bug #53305)
* Split "All topics" feed into "New Topics" and "Active Topics" feeds.
* It is no longer possible to persist a solution for the login CAPTCHA.
* Friends and foes will not show up as private message rule options if their respective UCP modules are disabled. (Bug #51155)
* Offer for guests to log in for egosearch and unreadposts search before the search permissions check. (Bug #51585)
* Allow ban reason and length to be selected and copied in ACP and subsilver2 MCP. (Bug #51095)
* Correctly set last modified headers. (Bug #54245)
* Make word censoring case insensitive. (Bug #54265)
* Fulltext-MySQL search for keywords and username at the same time. (Bug #54325)
* Various XHTML and CSS mistakes in prosilver and subsilver2. (Bugs #54705, #55895, #57505, #57875)
* Cleanly handle forum/topic not found in ATOM Feeds. (Bug #54295)
* PHP 5.3 compatibility: Check if function dl() exists before calling it. (Bug #54665)
* PHP 5.3 compatibility: Disable E_DEPRECATED on startup to keep set_magic_quotes_runtime(0) quiet. (Bug #54495)
* Correctly replace table prefix before inserting schema data into the database. (Bug #54815)
* Use memcache::replace() instead of memcache::set() for existing keys to prevent problems.
* Check for required functions in eAccelerator. (Bug #54465)
* Use correct RFC 3339 date format in ATOM feed. (Bug #55005)
* Do not deliver topics from unreadable or passworded forums in the news feed. (Bug #54345)
* Restore user language choice to compiled stylesheets. (Bug #54035)
* Do not permit unauthorised users to delete private messages from folder listing. (Bug #54355)
* Handle export of private messages where all recipients were deleted. (Bug #50985)
* Add ability to disable overall (aka board-wide) feed.
* Do not pass new_link parameter when creating a persistent connection with mysql. (Bug #55785)
* Improved search query performance through sorting words by their occurance. (Bug #21555)
* Strictly check whether a moderator can post in the destination forum when moving topic. (Bug #56255)
* Do not unsubscribe users from topics replying with quickreply. (Bug #56235)
* Don't submit when pressing enter on preview button. (Bug #54395)
* Load reCAPTCHA over https when using a secure connection to the board. (Bug #55755)
* Don't send activation email when user tries to change email without permission. (Bug #56335)
* Correctly orientate quoted text image on RTL languages. (Bug #33745)
* Fall back to default language email template if specified file does not exist. (Bug #35595)
* Database updater now separates ADD COLUMN from SET NOT NULL and SET DEFAULT, when using PostgreSQL <= 7.4 (Bug #54435)
* Styles adjustment to correctly display an order of rtl/ltr mixed content. (Bugs #55485, #55545)
* Do not store email templates in database. (Bug #54505)
* Fix problems with firebird by no longer using 'count' as a column alias. (Bug #57455)
* Make user_email_hash() function independent from system's architecture. (Bug #57755)
* Global announcements could not be accessed on a board using Firebird as the database server. (Bug #57525)
* Do not delete unrelated attachments when deleting empty forums. (Bug #57375)
* Update process: Store expected resulting file contents in cache and do not suggest further merges if the contents match, also fixes infinite merge loop (Bug #54075)
Users browsing this forum: No registered users and 2 guests
