Dragnix.Net http://dragnix.com/Msg_Board/phpBB/ |
The board has been updated to v2.0.21 http://dragnix.com/Msg_Board/phpBB/viewtopic.php?f=7&t=799 |
Page 1 of 1 |
Author: | Admin [ Thu Jun 08, 2006 10:24 pm ] |
Post subject: | The board has been updated to v2.0.21 |
This release is a cumulative bug fix update, as well as including a number of minor security fixes. # [Fix] Changes to random number generator code to explicitly truncate the length of the string # [Fix] Quoting on boards with HTML enabled # [Fix] Special characters on boards with HTML enabled # [Fix] Redirect to list if cancelling deletion of ranks, smilies or word censors # [Fix] Missing error message if an inactive user tried to login (Bug #1598) # [Fix] Do not alter post counts when just removing a poll (Bug #1602) # [Fix] Correct error in removal of old session keys # [Fix] Changed filtering of short search terms # [Sec] Improved filtering on language selection (also addresses a number of bug reports related to missing languages) # [Change] Backported more efficient highlighting code from Olympus # [Change] Backported zlib emulation code so that there is only a single confirmation image even if zlib is not available |
Author: | Jishdefish [ Fri Jul 07, 2006 4:16 pm ] |
Post subject: | |
I'd like to report a bug: If you don't mind. It seems when you use <and> as brakets all the words except for one are removed..... I know I am being kind of picky but I like to use <these> and am a little bothered by that.... sorry ![]() |
Author: | Tempest [ Fri Jul 07, 2006 8:23 pm ] |
Post subject: | |
<something> denote instruction for html. If you need to post something between brackets, you can use [something] or alternatively put a check into the "Disable HTML in this post" checkbox on the posting screen. <This is a test with html disabled> You can also change your profile to never allow html in post by default. I haven't tested it but it should be equivalent of putting a check aside "Disable HTML in this post" checkbox. |
Page 1 of 1 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
