It is currently Fri Jun 28, 2024 9:22 pm
Post new topic Reply to topic  [ 2 posts ]
 Post subject: The board has been updated to v2.0.20
PostPosted: Tue Apr 25, 2006 7:37 pm
Site Admin
This release is a cumulative bug fix update, as well as including a number of minor security fixes.
# [Fix] Prevent login attempts from incrementing for inactive users
# [Fix] Do not check maximum login attempts on re-authentication to the admin panel - tomknight
# [Fix] Regenerate session keys on password change
# [Fix] retrieving category rows in index.php (Bug #90)
# [Fix] improved index performance by determining the permissions before iterating through all forums (Bug #91)
# [Fix] Better handling of short usernames within the search (bug #105)
# [Fix] Send a no-cache header on admin pages as well as normal board pages (Bug #149)
# [Fix] Apply word censors to the message when quoting it (Bug #405)
# [Fix] Improved performance of query in admin_groups (Bug #753)
# [Fix] Workaround for an issue in either PHP or MSSQL resulting in a space being returned instead of an empty string (bug #830)
# [Fix] Correct use of default_style config value (Bug #861)
# [Fix] Replace unneeded unset calls in admin_db_utilities.php - vanderaj
# [Fix] Improved error handling in modcp.php
# [Fix] Improved handling of forums to which the user does not have any explicit permissions - vanderaj
# [Fix] Assorted fixes and cleanup of admin_ranks.php, now requires confirmation of deletions
# [Fix] Assorted fixes and cleanup of admin_words.php, now requires confirmation of deletions
# [Fix] Addition and editing of smilies can no longer be performed via GET, now requires confirmation of deletions
# [Fix] Escape group names in admin_groups.php
# [Sec] Replace strip_tags with htmlspecialchars in private message subject
# [Sec] Some changes to HTML handling if enabled
# [Sec] Escape any special characters in reverse dns - Anthrax101
# [Sec] Typecast poll id values - Anthrax101
# [Sec] Added configurable search flood control to reduce the effect of DoS style attacks
# [Sec] Changed the way we create "random" values for use as keys - chinchilla/Anthrax101
# [Sec] Enabled Visual Confirmation by default
# [Change] Changed handling of the case where a selected style doesn't exist in the database
# [Change] Changed handling of topic pruning to improve performance
# [Change] Changed default forum permissions to only allow registered users to post in new forums
 Post subject:
PostPosted: Wed Apr 26, 2006 3:18 pm
The Corruption
semi random question: how long does someone have to be away to be considered an inactive user?
Danger lurks in ordinary places
You just don't see it coming.
Live for something. Die for nothing.
Users browsing this forum: No registered users and 6 guests
You can reply to topics in this forum
