which gas?
Post anything related to dragons in this forum.
which gas do you think would help a dragon levitate better?
Poll ended at Sat Aug 20, 2005 2:45 pm
hydrogen
1
33%
methane
1
33%
combination
1
33%
magic
0
No votes
Total votes: 3
Tightwad
Location: Under your bed with a really, really big knife
which gas?
Post by Chalgrish »
I was thinking about how many different theories there are about how dragons fly while carrying their incredible mass. is it hydrogen, which can be produced by bacteria in a dragon's gut, and is a highly reactive light gas,methane which is produced in digestion and is a hydrocarbon, which is easy to burn. OR do you think that they float with a combo of the two, by magic, o r nothing, they just use their wings?
This poll will run for 2 weeks, at which point I will hopefully have more than 10 responses.
Wanderer
Wanderer
Post by Blacksails »
Methane, definitely. It all fits. Natural by-product, lighter than air, and also explains the fire-breathing capabilities of the stereotypical dragon.
Trapped In A Permanent Good Mood!
My Name Is Blacksails, and I am CANADIAN!
Tightwad
Post by Chalgrish »
hydrogen is easily producedby bacteria in a dragon's gut, is the lightest gas in existence, and is even more flammable than methane
Site Admin
Post by Tempest »
I never liked the word magic since it's more a word used for a lack of explanation than an attempt to explain a phenomenon.
But the real concept here isn't about if hydrogen, methane or helium is lighter than air but about the actual density of the gas itself (the Ideal gas law).
<tt>The "Ideal Gas Law" says that m = PVM / RT where:
m = mass of the gas in grams
P = pressure inside the container (in atmospheres)
V = volume in liters
M = Molecular weight of the gas
R = 0.082
T = Absolute temperature (in Kelvin)</tt>
For example, let say you have a balloon that is fully inflated with helium and someone wonder if adding more helium would increase the lift. Well, if the balloon doesn't get any bigger at all, the answer is no. If the balloon stretches a tiny bit bigger, then you would have to know if the tiny increase in size add enough lift to offset the extra weight of helium added.
So a dragon has no advantage to hold the gas in a compressed state (since in this state it would become heavier than air) and if uncompressed, then the dragon would have to look like the Goodyear blimp to feel any real difference. It's about the same thing in various events where you have someone holding a large grape of balloons filled with helium, while I will admit that the balloons are not filled entirely with helium, I don't think the person holding them feels any lighter.
I'm not sure if you have heard of Larry Walters who managed in being carried into the sky by a giant bouquet of colorful toy balloons in 1982, but I have an image here to show the size and the amount of balloons needed to lift a single man.
Also, hydrogen possesses several unique properties that render it more hazardous than most other flammable gases. It burns with an extremely hot, but non-luminous flame. Hydrogen has an unusually large flammability range and it can form ignitable mixtures between 4 and 75 percent by volume in air but what make it more dangerous is that the range for explosive mixtures is also very broad. Given confinement and good mixing, hydrogen can be detonated over the range of 18 to 59 percent by volume in air.
So I do not really like the concept of using hydrogen as a flames thrower. If you have done the experiment of putting a flame in a test tube containing hydrogen gas, it makes a loud pop sound (small explosion). Truly, if I had to work with a gas to create a flame, I would use methane over hydrogen since explosive mixtures are too easily formed with the later.
Tightwad
Post by Chalgrish »
mind the fact that a juvenile dragon could be up to 30 feet long, tip to tail, and since platinum is a catalyst for fire from hydrogen, the best combination would be 30 cubic liters of hydrogen to 5 liters methane, rendering in a easy flotation and fire. therefore, it is easily said that dragons possess a flight bladder,or several, therefore making it lighter in an uncompressed state of matter. A dragon could easily control these bladders, controlling lift, flight, and power. using thermals and a 40 foot wingspan, could provide the neccesary lift to allow a dragon to reach altitudes that a human couldn't. A dragon's physiology
