Brainstorm about a new Rp.
- Dragonfish Warrior
- Location: In a sunken Nuclear Submarine using the satellite commlink to talk to my fellow dragon belivers.....
Okay, so basically I REALLY want to create a good pirate-themed Role-Player, but I want it with a twist of some sort, some other setting than 1800's open seas. This is basically a brainstorming session, if anyone wants to put their two cents in it would be appreciated.
Anything is Possible...
And Yet, Nothing is Probable.
- The Endless Prophet
- Contact:
I was thinking of changing the ships to Zeppelins with a negatively charged energy field turning water into 'hot vapor' You know, the opposite of turning water into a solid ('hot ice') with a positively charged electric field. I had designed an airship with sails, a collapsible catwalk/deck and everything, but then I thought better of it. It was kinda cheesy for two reasons: A) If you had the technology to produce a negatively charged energy field, why would you use zeppelins and not some sort of space-compatible vehicle. B) Pirating wouldn't really work with Zeppelins, they are too prone to projectiles.
- Contact:
- Knowledgeable Dragon
- Contact:
1 Late medieval/early renaissance with Monitors, schooners, and Treaders.
2 Early medieval with ballistae and no gunpowder.
3 High myth with hippocampus and eastern sea dragons
4 High or medium-high magic, with some ships being able to hire wizards to make their ships fly, and merchants being left with traditional defenses.
5 and most importantly: no major continents. The world is an Archipelago.
"Thunder is good, thunder is impressive, but it's lightning that does the work." ~Samuel Clemens
Mah Griffon is © Todd Lockwood.
I think I am hoping too much to think of something right off of the bat. I have a good storyline, so I'll stick to that, and place it in the Carribean, it's been done, but not the way I do it. Anyway, I started it:
http://roleplayacademy.freeforums.org/v ... .php?t=130
- Contact:
- Contact:
- Dragon's Egg
- Location: I live on Kadora, the third planet from the sun, Andrem.
- Contact:
- Proficient Young Dragon
this is one that i've been thing about jish.
how about the ships not only can float along the surface of the water, but with the help of elementals, depending on the kind, can go through different types of terrain.
like have a combination, fire and air it can fly, air and water it can fly and can under the water, earth and air it can fly and skim along the ground.
just an idea
just an idea
