Page 1 of 1
The board has been updated to v2.0.18
Posted: Mon Oct 31, 2005 6:53 pm
by Admin
This is a major update to the 2.0.x codebase and includes fixes for numerous bugs.
# [Fix] incorrect handling of password resets if admin activation is enabled (Bug #88)
# [Fix] retrieving category rows in index.php (Bug #90)
# [Fix] improved index performance by determining the permissions before iterating through all forums (Bug #91)
# [Fix] wrong topic redirection after login redirect (Bug #94)
# [Fix] improved handling of username lists in admin_ug_auth.php (Bug #98)
# [Fix] incorrect removal of bbcode_uid values if bbcode has been turned off (Bug #100)
# [Fix] correctly preview signature if editing other users posts (Bug #101)
# [Fix] incorrect alt tag on generated search images in groupcp.php, viewtopic.php and usercp_viewprofile.php (Bug #102)
# [Fix] consistent forum ordering in all dropdown boxes (Bug #106)
# [Fix] correctly get compression status in page_tail.php and page_footer_admin.php (Bug #117)
# [Fix] set page title on summary page of groupcp.php (bug #125)
# [Fix] correctly test style and avatar in usercp_register.php (bug #129 and #317)
# [Fix] handling of reactivation notifications if admin activation is enabled (Bug #145)
# [Fix] handling of both forms of translation information used in language packs (Bug #159)
# [Fix] key length for activation keys fixed in usercp_sendpassword.php (Bug #171)
# [Fix] use GENERAL_MESSAGE constant in message_die instead of MESSAGE (Bug #176)
# [Fix] incorrect handling of move stubs (Bug #179)
# [Fix] wrong mode_type in memberlist (Bug #187)
# [Fix] SQL errors when setting maximum PMs to 0 (Bug #188)
# [Fix] removed unused variable from topic_notify email template (Bug #210)
# [Fix] removed unset variable from smilies popup window title (Bug #224)
# [Fix] removed duplicate template assignment from admin_board.php (Bug #226)
# [Fix] incorrect search link for guest posts in modcp.php (Bug #254)
# [Fix] all users removed from topics watch table on special occassions (Bug #271)
# [Fix] correctly check returned value from strpos in append_sid function (Bug #275)
# [Fix] correctly display username in private message notification (Bug #278)
# [Fix] fixed "var-by-ref" errors (Bug #322)
# [Fix] changed redirection to installation (Bug #325)
# [Fix] added timout of 10 seconds to version check (Bug #348)
# [Fix] fixed user_level default in postgresql schema file (Bug #444)
# [Fix] multiple minor HTML issues with subSilver
# [Change] deprecated the use of some PHP 3 compatability functions in favour of the native equivalents
# [Change] added 60 days limit for grabbing unread topics in index.php
# [Sec] backport of session keys system from olympus
# [Sec] fixed email bans to use the same pattern as email validation and allow wildcard domain bans
# [Sec] fixed validation of topic type when posting
# [Sec] unset database password once it is no longer needed
# [Sec] fixed potential to select images outside the specified path as avatars or smilies
# [Sec] fix globals de-registration code for PHP5 - (Stefan Esser/Matt Kavanagh)
# [Sec] changed avatar gallery code sections to prevent possible injection points (AnthraX101)
# [Sec] signature field is not properly sanitised for user input when an error occurs while accessing the avatar gallery (AnthraX101)
# [Sec] check to_username and ownership when editing a PM (AnthraX101)
# [Sec] fixed ability to edit PM's you did not send (depablo84)
# [Sec] compare imagetype on avatar uploading to match the file extension from uploaded file
Posted: Mon Oct 31, 2005 8:04 pm
by Chalgrish
ooh.... lookit all the fixes. That is incredible, seriously. May this board grow with leaps and bounds and wonderful stuff!
