Page 1 of 1
Parting of the ways
Posted: Mon Nov 14, 2005 3:38 pm
by Jadrian DragonFreind
You wake up in the wagon, outside of Uncataya. As you wake up, And buckle on your weapons, you hear a scream. you and your companions jump put of the wagons, and see an old elf woman come screaming out of the woods. behind her is a large bear, you and your comrades look at each other, deciding what to do.
Posted: Mon Nov 14, 2005 8:23 pm
OCC; This is a huge bear ok, were talking ten feet, k? so dont try this
Occ: sorr
Posted: Tue Nov 15, 2005 11:20 am
OOC: sorr description.
There are buildings surrounding you, the wagons behind you, and the bears in front of you. The little old...woman/elf is going to die unless you intervene, and then the bear will most likely turn on you.
ok third time lucky
Posted: Tue Nov 15, 2005 5:30 pm
You're in a light drowse, when the wagons suddenly stop. You atand up, and jump out of the wagons. The Sun hits you like a club, the brightness blinding you slightly. you and your companions stand, trying to pull yourselves together. Suddenly you hear a scream. A small girl runs out of the forest, followed by a Narkana, a huge mountain bear. You grab your weapons and glance at each other, debating what to do.
