This release is a cumulative bug fix update, as well as including a number of minor security fixes.
# [Fix] Changes to random number generator code to explicitly truncate the length of the string
# [Fix] Quoting on boards with HTML enabled
# [Fix] Special characters on boards with HTML enabled
# [Fix] Redirect to list if cancelling deletion of ranks, smilies or word censors
# [Fix] Missing error message if an inactive user tried to login (Bug #1598)
# [Fix] Do not alter post counts when just removing a poll (Bug #1602)
# [Fix] Correct error in removal of old session keys
# [Fix] Changed filtering of short search terms
# [Sec] Improved filtering on language selection (also addresses a number of bug reports related to missing languages)
# [Change] Backported more efficient highlighting code from Olympus
# [Change] Backported zlib emulation code so that there is only a single confirmation image even if zlib is not available
The board has been updated to v2.0.21
- Site Admin
- Dragonfish Warrior
- Location: In a sunken Nuclear Submarine using the satellite commlink to talk to my fellow dragon belivers.....
- Site Admin
<something> denote instruction for html. If you need to post something between brackets, you can use [something] or alternatively put a check into the "Disable HTML in this post" checkbox on the posting screen.
<This is a test with html disabled>
You can also change your profile to never allow html in post by default. I haven't tested it but it should be equivalent of putting a check aside "Disable HTML in this post" checkbox.
