Dragnix.Net https://dragnix.com/Msg_Board/phpBB/ |
The board has been updated to v3.0.7 https://dragnix.com/Msg_Board/phpBB/viewtopic.php?f=7&t=1837 |
Page 1 of 1 |
Author: | Admin [ Tue Mar 02, 2010 11:43 am ] |
Post subject: | The board has been updated to v3.0.7 |
This update is a maintenance release fixing a number of a bugs as well as improving on usability and performance. * Warn users about potentially dangerous BBcodes. * Forum feed no longer includes posts of subforums. * Speed up topic move operation by adding an index for topic_id on the topics track table. (Bug #56545) * Move redirect into a hidden field to avoid issues with mod_security. (Bug #54145) * Log user activations through inactive users ACP. (Bug #30145) * Alter ACP user quick tools interface to reduce confusion with the delete operation. * Show a proper preview for the Q&A CAPTCHA. (Bug #56365) * Send time of last item instead of current time in ATOM Feeds. (Bug #53305) * Split "All topics" feed into "New Topics" and "Active Topics" feeds. * It is no longer possible to persist a solution for the login CAPTCHA. * Friends and foes will not show up as private message rule options if their respective UCP modules are disabled. (Bug #51155) * Offer for guests to log in for egosearch and unreadposts search before the search permissions check. (Bug #51585) * Allow ban reason and length to be selected and copied in ACP and subsilver2 MCP. (Bug #51095) * Correctly set last modified headers. (Bug #54245) * Make word censoring case insensitive. (Bug #54265) * Fulltext-MySQL search for keywords and username at the same time. (Bug #54325) * Various XHTML and CSS mistakes in prosilver and subsilver2. (Bugs #54705, #55895, #57505, #57875) * Cleanly handle forum/topic not found in ATOM Feeds. (Bug #54295) * PHP 5.3 compatibility: Check if function dl() exists before calling it. (Bug #54665) * PHP 5.3 compatibility: Disable E_DEPRECATED on startup to keep set_magic_quotes_runtime(0) quiet. (Bug #54495) * Correctly replace table prefix before inserting schema data into the database. (Bug #54815) * Use memcache::replace() instead of memcache::set() for existing keys to prevent problems. * Check for required functions in eAccelerator. (Bug #54465) * Use correct RFC 3339 date format in ATOM feed. (Bug #55005) * Do not deliver topics from unreadable or passworded forums in the news feed. (Bug #54345) * Restore user language choice to compiled stylesheets. (Bug #54035) * Do not permit unauthorised users to delete private messages from folder listing. (Bug #54355) * Handle export of private messages where all recipients were deleted. (Bug #50985) * Add ability to disable overall (aka board-wide) feed. * Do not pass new_link parameter when creating a persistent connection with mysql. (Bug #55785) * Improved search query performance through sorting words by their occurance. (Bug #21555) * Strictly check whether a moderator can post in the destination forum when moving topic. (Bug #56255) * Do not unsubscribe users from topics replying with quickreply. (Bug #56235) * Don't submit when pressing enter on preview button. (Bug #54395) * Load reCAPTCHA over https when using a secure connection to the board. (Bug #55755) * Don't send activation email when user tries to change email without permission. (Bug #56335) * Correctly orientate quoted text image on RTL languages. (Bug #33745) * Fall back to default language email template if specified file does not exist. (Bug #35595) * Database updater now separates ADD COLUMN from SET NOT NULL and SET DEFAULT, when using PostgreSQL <= 7.4 (Bug #54435) * Styles adjustment to correctly display an order of rtl/ltr mixed content. (Bugs #55485, #55545) * Do not store email templates in database. (Bug #54505) * Fix problems with firebird by no longer using 'count' as a column alias. (Bug #57455) * Make user_email_hash() function independent from system's architecture. (Bug #57755) * Global announcements could not be accessed on a board using Firebird as the database server. (Bug #57525) * Do not delete unrelated attachments when deleting empty forums. (Bug #57375) * Update process: Store expected resulting file contents in cache and do not suggest further merges if the contents match, also fixes infinite merge loop (Bug #54075) |
Page 1 of 1 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
